frank_n
- Central NJ
I am going to install a 200amp service. The NEC alllows for 3-2/0 wires in a 1 1/2 PVC. Please answer these questions.
1- Should I use 2" PVC to make the pulling easier? (There is 1 90 deg sweep)
2- Does the service wire have to be insulated with THWN, or is THHN or THN ok? (I cannot find this in the code book)
3- Is it required that a pipes going into the Hot Water Boiler be bonded like the pipes of a Water heater?
Thanks in advance,
Frank
Thanks in advance,
Frank
