james wuebker
- Iowa
Farm has the meter out on the pole about 120' from the house. This has a main breaker disconnect on it. (240 volts single phase.)Need to feed the house for 200 amp panel. The panel in the house has a main breaker in it. From the pole to the house using only pvc pipe. If I remember correctly I only have to run 3 wires from the outside main to the house. 2 ungrounded & 1 grounded conductor. Shouldn't have to run the 4th wire. At the house put in the ground rod and feed to the panel. The neutral and the grounding wire should be bonded together. Not sure if they are using copper or pvc for water to the house. I most of the time run 4 wire but somewhere in the code book I remember that you only have to use 3 wires feeding the house because the wires would be in pvc and not steel. I'm I correct on this?
Thanks!
Jim
Thanks!
Jim
