The Iceman
- Florida
I'm having a problem interpreting 210.6 (A). Does this article mean that in a dwelling unit (for example) you can,t have a two gang box for two switches supplying lighting fixtures, each switch on a separate 120 volt circuit, if the ungrounded (hot) conductors are on seperate phases (240 volt)?
If I'm understanding this correctly what if one switch supplied lighting and the other switched a receptacle?
I hope this made sense. I appreciate any help on this one.
