marcelo
- Port Chester, NY
Good morning Gentleman,
Here is the picture: An existing 200A service with a meter pan/200A breaker disconnect combination feeding a Main Panel in the garage thru a 4/0 SER cable. This garage main panel feeds another existing outdoor sub-panel that feeds the existing swimming pool equipment. Here comes the trick part!
We installed a new 20KW generator and switched the whole house with a new 200A transfer switch mounted outside right next to the meter pan, the SER cable in the meter pan was re-routed to the transfer switch.
The inspector failed the job because he is claiming 680.25 and he's telling me the 4/0 SER needs to me removed and a raceway needs to be installed between the transfer switch and the garage main panel.
I'm questioning because the garage main panel is not the swimming pool panel, it's feeding the rest of the house also and we didn't touch anything related to the pool.
Your comments will be greatly appreciated...
Thank You,
Marcelo Zanetti
Thank You,
Marcelo Zanetti
