sceepe
I was just reading Nov 2004 EC&M. Has good article on the top 25 code changes (how they rank them). Check it out if you haven't. One item I have not heard about is that: flourescent lights that have double ended lamps and ballast that can be serviced in place or reballasted must have a disconnecting means to disconnect all conductors including the neutral.
This Requirement becomes effective 1/1/08. I suppose troffers or the ballasts will have to come with a 2 pole disconnect switch built into each fixture? Would a quick connect wiring harness for the ballast work as a disconnect if the line side wires were shielded from contact?
