J Jerome Shepard Member Location Wisconsin Nov 12, 2019 #1 What size conductors are required to feed a load center with a 200a main breaker from a 200a main disconnect, all within 75 feet
charlie b Moderator Staff member Location Lockport, IL Occupation Retired Electrical Engineer Nov 12, 2019 #2 How about giving us your answer first.
infinity Moderator Staff member Location New Jersey Occupation Journeyman Electrician (retired) Nov 12, 2019 #3 Is it a dwelling unit? Calculated load?
Strombea Senior Member Location Prescott, Arizona, USA Nov 12, 2019 #5 Hahaha no easy answers!! Simple chart should do the trick copper: 3/0 for everything except residential service feeders to entire home you can use 2/0.
kwired Electron manager Location NE Nebraska Occupation EC Nov 13, 2019 #6 Majority of time you will need 3/0 copper or 4/0 aluminum. But there are many possible conditions that may require adjusting the results and you give us no details to tell if we may need to make such adjustments.
