Fred B
- Upstate, NY
- Electrician
I have seen it. Cheap DIY installed EVSE sold by Amazon or Temu that allow the home owner to set the charge rates. The 40A rate not fast enough so just bump it up to the 48A rate because after all it has a 50A breaker, and then after 6hrs on charge the whole thing gets hot melting down the range plug. HO goes into big box and sees 2 50A receptacles, one 2 or 3 dollars less than the other, Which one do you think they are going to grab?I have never seen such a failure, perhaps one DIY post on reddit where the charger was programmed for max ?
Seen one at a house that I went to for another reason, smelt hot wire and finally found one of the Cheap 120V EVSE chargers plugged in with a small gauge extension cord that the cord end had already melted down and was smoking.
Then you have these units being installed where total system load will cause and issue at the full rate, No one looking at the house loads prior to the install by the DIY/HO, the HO may ask an electrician, but more likely a GC or handyman to add a range plug in their garage. They won't have a clue as to load calculations (Or even care).
Untrained persons have no business playing with these units. How many hours or years of training have many of you gone through to become a qualified licensed electrician? And then just want to hand over the reins to the HO or DIY to do as they please?
I know you can't fix stupid, but should be allowed to regulate to protect others from stupid.
And for those that may ask who is harmed or risk of harm by a DIY/HO doing their own work and it fails? How about the first responders and firemen when the whole thing goes up in smoke, or property damage to a neighboring property when the garage becomes engulfed from an improperly installed EVSE or one that might have been OK when inspected (if it was) but the HO altered the settings.
If the EVSE was all that simple as suggested by some posts, Why so many threads posted here as to the confusion even by those who are electricians as to the varying nuances of 625 and what it means?
Seems we as a trade have such a hard time with regulating so that only "Qualified" persons are installing things. HVAC has no such problem prohibiting sale of equipment or restrict who can install equipment, so why don't or can't we as a trade? Is Electrical components so much less dangerous than HVAC?
