Would it be possible for a 120V coolant pump(nameplate 120V/60Hz/1.15A) to run for an extended period of time on 208V? I got a call to a machine shop that was having problems with a grinding machine. After metering out the terminal strip (listed on the print as 120V) I found that someone had taken power from the wild leg off the line side of the starter to feed the coolant pump switch.I am told that it has operated this way for at least 5 years since the equipment was brought into the building. After diagnosing the problem(pinched wire against enclosure) I hooked it up the way it should be and it ran fine, Machine operator tells me that the coolant flow is less now to the cutting tool.All I can think is that the higher voltage was turning the pump at a faster rpm.There were also indicator lights that were supposedly working on the 208voltage as well.
