I have equipment that is powered from a 208V 3 phase source. Inside the equipment I have a separate piece of equipment that will have its own 115V single phase power source. The 3 Phases conductors enter the equipment and are inserted into a distribution block, and from there feed the rest of the equipment through terminal blocks. The non plug end of the power chord (hot, neutral ground) for the 115V equipment enters the equipment and is inserted into terminal blocks. The single piece of electronics equipment is then powered from these 115V terminal blocks.
My concern is with grounding the equipment. I have my main equipment grounding conductor which is bonded to the accessible parts of the equipment and back to the 208V 3 phase source. Do I only connect the 115V piece of equipment and the 115V power chord ground into a single terminal block, and not bond it to any other accessible parts on the equipment?
Summation of problem: 1 piece of equipment, two seperate power sources, how are the two sources grounded?
