I don't work with three-phase systems (I'm a motorhome electrical troubleshooter) and I've run into a situation that has got me puzzled. One of the workers at the factory plugged his drop light into a 120V 20A receptacle and the light got bright -- really, really bright. I checked the voltage at the receptacle and measured 120V Hot to Ground, 240V Hot to Neutral, and 208V Neutral to Ground. What the heck is going on? I got my boss to call the Maintenance Department and I'm not going to monkey around with the building wiring, but I'm curious as to what could cause this situation. Would this occur if the neutral was accidentally connected to the B phase of a high-leg delta? How about if there were an open neutral on a wye?
Can anyone recommend any good websites, books, etc. on three-phase theory and calculations?
