- Massachusetts
Re: 20A GFCI circuit with 15A receptacles
Peg I also agree with the others, if you compare the same grade receptacle from the same manufacturer you will find that the 'guts' are identical.
15 amp receptacles are in fact 20 amp receptacles without the extra slot.
Here is a Hubbell 15 Amp Heavy Duty Specification Grade Duplex Receptacle.
Here is a Hubbell 20 Amp Heavy Duty Specification Grade Duplex Receptacle.
Inside these are the same.
Now take a look at a lower grade Hubbell duplex. This is still a much better receptacle than the $0.49 ones found at the bargain outlets, regardless of a 15 or 20 amp rating.
As you can see this grade is much less robust than the ones above.
So IMO the best way to get a good receptacle for your clients is to specify a grade not an rating.
There is no reason for 20 amp receptacles in a dwelling unit, have you seen any dwelling unit appliances that require a 20 amp receptacle?
[ October 08, 2005, 11:12 AM: Message edited by: iwire ]
