Re: 20A minimum CB
For UL489 devices the minimum is 15a. Even though there are some 10a rated devices of the same frame size I'm not aware that there any that are available with a UL489 listed.
Reference 240.6 Standard Ampere ratings.
There are UL1077 supplementary protectors for a wide range of amp ratings available but they must be applied per 240.10 and are not to considered as a substitute for branch circuit over-current protection. The are available in ampacities in a range of .5a to about 60a. However, they are different than the UL489 devices in that they are often available with a choice of at least 2 time/current trip curves.
Again, they can not be used as a subsitute for a UL489 listed device.
