210.11(C)(4)
elecmen
NH
Can the receptacle for the garage door opener be on this circuit or does it have to be on a different circuit
Little Bill
Tennessee NEC:2017
Semi-Retired Electrician
@elecmen
Could you please update your profile? Most info was lost when new software/platform was introduced.
Please list your occupation and at least the state you're in.
elecmen
NH
Hi Little Bill, can’t find a way to edit my profile only the picture. With that said I’m an electrician from NH. I see the code I referenced says no other outlets with an exception for outdoor outlet. I ask because I have someone who says you can add the opener outlet to this circuit. This was installed under 2017 BEC
Little Bill
Tennessee NEC:2017
Thanks for the info on your profile, Roger fixed it.
As for your question, I think "no other outlets" means not leaving the garage. I don't see a problem putting the door openers on this circuit. I do it all the time. I don't know what changes have been made past the 2017. Maybe others could chime in on that.
