Bell County
- Bell County Texas
I’m an inspector in Bell County, Texas, a master electrician and graduate from the NJATC. Some of the electricians are not installing arc-fault breakers in new residential houses,only installing AFCI outlets.They are quoting 210.12 (A)(4) of the 2017 NEC. Being knowledgeable with the NEC, and also using the handbook’s commentary,particular Commentary Table 210.2, it’s clear to me the home runs have to be protected, and the combination of “identified” and “listed” devices do not currently exist.
To make the matter worse, I contacted the Chief Electrical Inspector and Electrical Occupations & Code Specialist at the Texas Department of Licensing & Regulation, and in writing,was informed that 210.12 (A)(4) does allow the use of standard 15 and 20amp breakers (non-arc fault), meaning the home runs are not arc-fault protected,in new houses. I’ve meet with about 15 local electrical contractors to discuss 210.12 (A)(4).They all agree the “home run” must be AFCI protected.
The issue is there are some electrical contractors that are interpreting 210.12 (A)(4) to mean a standard breaker can be used at the source, and the Texas Department of Licensing & Regulation is backing this interpretation.
