synchro
- Chicago, IL
- EE
As an update to this odd ball situation, another option that surfaced is one of these Bussman covers that have a receptacle and a fuse.
They actually make a version that is a 4S cover.
A co-worker calls this a british style plug because 'all plugs in the UK are fused' not sure if that is accurate.
Using this supplemental protection can be provided. Granted that is only a 15A receptacle, and that is not a type-S fuse holder.
I'd probably put a 20A fuse in it for a I am guessing a ~1500W microwave.
Another alternative is a small Eaton 30A safety switch that uses a plug fuse, with part number DP111NGB. It's about 5" x 5" x 3.5". It accepts up to 8 AWG on its line side.
https://www.walmart.com/ip/Eaton-Corporation-30a-Safety-Switch-DP111NGB/154249325
https://assets.unilogcorp.com/2/ITE...0e8e4f15f9c4a9b7d764373e7c136d76943aadbc5.pdf
There's also a 2-pole version DP221NGB .
