Designer69
210.25 says that branch circuits from a dwelling unit shall supply only loads within that dwelling unit.
Well this dwelling unit has 2 means of egress and qualifies for emergency egress lighting (as far as I can make sense of the bldg code).
I just want to make sure that I can still bring in an emergency circuit from outside the dwelling unit (basement where emerg. panel is) into the dwelling unit for the emerg. egress lights and that this is ok.
This is a dormitory setup type building, with only one meter for the building, but the dwelling unit/apartment is separated from the other "boarding" areas and has its own panelboard.
Thank you
Thank you
