A/A Fuel GTX
- WI & AZ
- Electrician
Is it acceptable to run NM-B up through an island cabinet to feed the required receptacle (s) ? I've seen it done that way but have also seen FMC and MC used. Just wondering.....
haskindm said:Someone is the AHJ, there has to be. Read the definition of the AHJ. It may be the building owner, but someone has to be the AHJ, otherwise the NEC will not work. For example all equipment must be "approved". The approver is the AHJ.
77401 said:what does your AHJ allow for the disposal?
