david
- Pennsylvania
Though I agree with your position of where they are required, a quick search of the subject ground fault protection in schools professionals commenting on the subject believe the protection should be included in the areas you describe in this thread. One 2011 published example from the on line search.
Where should GCFIs be installed?
The National Electrical Codes (NEC) National Fire Protection Associations (NFPA) 70 requires GFCIs for receptacles
located outdoors, near swimming pools and vending machines; and also in bathrooms, garages, kitchens, crawl
spaces, and near laundry machines and utility sinks.
In educational facilities, places where the installation of GFCIs are recommended include:
Science laboratories: Lab table sinks that include electrical outlets
Home economics rooms: Kitchen counters with sinks with electrical outlets
Industrial arts shops: Ideally, the circuit for the entire shop should be protected. Often shops have
overhead doors, allowing water to be tracked into the work area
Fine arts classrooms: Potters’ wheels use water to shape the clay; if the wheel is powered by an electrical
motor, protection is necessary
Swimming pools:
The requirements for electrical wiring in or adjacent to pools and spas are provided in
the National Electrical Code (NEC), which should be consulted by a qualified person.
Specific NEC requirements for GFCIs include: 125 volt receptacles within twenty feet of the inside walls of the
pool, lighting fixtures/outlets in the pool area between five feet and ten feet from the inside wall of the pool, and
motors/controllers used in electrically operated pool covers.
Locker rooms: Sinks with electrical outlets for hair dryers, etc.
Electrical outlets on the building exterior: Receptacles that are not part of the permanent wiring of the
building (such outlets hooked into portable generators for carnivals and similar temporary outdoor uses)
should have GFCIs
Wet or damp environments or where electrical devices could contact fluids
Swimming pools:
should have GFCIs
