hillbilly1
- North Georgia mountains
- Owner/electrical contractor
I know the two poles are common because of spas and the like, but a single pole gfci 30 are probably hard to find. Didn’t think about the A/C’s too. How often has that happened to make that big of a change in the code?While it does cover the RV receptacles, it was aimed at air conditioning equipment. The substantiation was about a person who was killed from touching an energized condenser unit at a dwelling unit. Eaton, Square D, Siemens, and GE all have single pole 30 amp GFCI breakers. Two pole GFCIs up to 60 amps are readily available.
