elpaso
New member
- El Paso, Texas
Section 220.54 states that a 5000va calculation should be used if the dryer is less than 5000 va. Section 220.82 B allows the nameplate rating ( which may be lower than 5000 va ) to be used in calculating the feeder and service requirements for dwellings. The two references seen to contridict each other, in what situation would one use each? Thanks.
