griffelectric
- USA
why does a 22kw standby generator use a 200amp transfer switch, if this generator only produces 91 amps 22000 / 240 volts ?
if you have a 200 amp residential service and you want a backup generator for standby power, should you install a 48kw generator
48000/240volts = 200amps, instead of a 22kw generator?
