- San Francisco Bay Area, CA, USA
- Electrical Engineer
Kind of a waste to use a VFD as a soft starter, but yes, sometimes that's the only option when the source supply is severely limited.So for a small compressor, even if you use a VFD, would you recommend using 'bang-bang' control.
With the lubrication issues that you describe, it seems to me that a VFD would still have substantial value, but it might be limited to 'full torque soft starting'. Though I doubt that this would be worth the cost of the VFD unless you had severe voltage drop issues (eg. large compressor in a home shop )
-Jon
As to recommending bang-bang? I don't know, there are some very successful VFD applications on compressors, it just depends a lot on the compressor mechanics; not all are built the same. A lot of older recips use a mechanical lube pump that has a critical speed necessary to make them work. People tend to discover that critical speed by frying the main compressor. Screw compressors and scroll compressors tend to lend themselves to VFD application a lot more readily.
