- Placerville, CA, USA
- Retired PV System Designer
Other then the occasional item like the OP has, there is little demand for anything but 120 volt, as there is seldom a tool less then 1400VA that runs above 240 volts, Electronic items (data processing and accessories in that area) are different, but usually are dual voltage capable.
Probably has some wanting 400Hz supply to run them now, they should be lighter weight then their 60 Hz counterparts.
400Hz generators (but not the engines) are also lighter than their 60Hz counterparts.
