Hello!
I could use just a little sanity check on a heater that I am installing. It was made for the EU but the manufacturer claims they sell many in the US without issue. Unfortunately, their tech support and manual are completely void of information (big shocker!). Anyway, the issue is that the label shows 208V-230V/1~/60hz but the wiring is also labeled L-N-G. I have 208V 3 phase available. I checked continuity between N and G and there is none. I believe I should be able to wire L1 to L and L2 to N but is there anything else I can test to make sure there wont be an issue not having a grounded neutral before I let the smoke out?
