230v line to neutral single phase IEC motor
I think this not a standard induction so the rules of engagement change. The two ratings for power are a bit of a clue.
It could be typical, be just rated differently. That fact the PF gets so high leads me to think this is built more around 50Hz but with a 60Hz rating just tossed in. Not that this could effect the OP however. In my limited experience motors are often over sized for the application when driving belts, fans, ect.
EDIT: the current is also more at 60 Hz...
Here is a pic of a similar motor I dealt with in a similar application for discussion purposes. Note the differences in rating:
thanks
rated shaft P
50 Hz 1.5 kw or 2 HP
60 1.8 kw or 2.4 HP
so fully rated at 60
Torque
50 Hz 7.25 lb-ft
60 Hz 7.3 lb-ft
essentially the same
so torque remains constant
shaft P = v x i x pf x eff (v x i = electrical power)
eff = Shaft P / (v x i x pf)
50 Hz 80%
60 Hz 79%
Now, having seen the nameplate, you could have done that a lot more simply.
The power is proportional to speed in both cases.
That can only happen with constant torque.
No need to make it any more complex than that.
Look at the cos phi. What does that tell you?
var increase because Xc decreases which improves pf since var = V^2 / Xc
small compared to the decrease in Z
230/8.4 = 27.4 Ohm (total R, Xl, Xc)
230/10 = 23 Ohm
27.4/23 ~ 1.2 or 20%
Cd
50 Hz 26.5
60 Hz 22.10
20% decrease, current increases 20% (8.4 x 1.2 ~ 10 A)
(Xl not included)
do you always answer a ? with a ? or do you ever actually ANSWER a ? ?
lol
not true
why is it constant?
you lack understanding
you are not alone
power is power lol
230/10 = 23 Ohm
Cd
50 Hz 26.5
60 Hz 22.10
(Xl not included)
lol
I wasn't answering a question. I was asking one.
Then why does my nameplate contradict the OPs?
it IS a standard 1 ph induction motor
not a constant torque motor (intentionally)
can't mix 1 ph and 3 ph
1 ph has capacitors whose X changes with freq, lowering Z, therefore increasing I for a constant v
power increases due to I increase
but speed increases which gives back the gain
Of course, gain by mathematical multiplication of two finalized concepts. But starting torque is just that: torque with no speed. Increasing the frequency causes the magnetic field to spin faster, but with a reduced density provided voltage stays that same. Its that density which is responsible for torque.
I was not describing the EM mechanism that generates torque
but the relationship of shaft torque based on varying speeds (and in this case Xc)
I can understand that, but I still maintain the its only part of the picture.
not for what we are discussing
a motor driving a load
if we know: v, I, pf, eff we know shaft power
does not matter what is going on in the motor (that is reflected in the above data)
add in rpm we know torque
from this we can determine the force on a belt
the volume/head capabilities of a pump
etc.
