Barjack
- St. Petersburg, FL
An existing spa has a 230V 1HP circulation pump on a 2 pole 20A breaker. The pool company we do service work for has added 120V cord and plug connected chemical feeder pumps to add chemicals into the spa. These feeder pumps cannot run when the circ pump is off. I know that a 230V contactor is an option, but why can't I pigtail off one of the lines of the 2 pole breaker, add a neutral and wire the receptacle. It sounds simple to me, but I can't help thinking I'm breaking a rule. The pump and the sub panel that feeds it are located in a vacpack (factory assembly consisting of a fiberglass enclosure housing the subpanel, pumps, light transformers, and other accessory items relating to pool functions). The receptacle would be installed directly from the subpanel.
