I have a 24 volt monorail track lighting system. It consists of a 120v single pole switch(that will eventually be changed to a dimmer)that turns on a 1000va 120/24V transformer. On the secondary side I ran #10 MC cable about 10 feet to a J-Box. At the J-Box I connected to the track power feed. Before I enegized the track i tested the output voltage and it read 27v.The track power feed cable drops down about 10 feet to the track.The track is about 14 feet long with 200 watts of load connected. When i turn on the transformer the secondary wire insulation starts to melt off(takes about 30 seconds). When i turned on the transformer the lights didn't come on either. Any idea of what is wrong?
