240.21 (B) 10ft tap rule
Makes sense if supplying say a 20 circuit panelboard with it, but he is supplying a 2 pole panelboard with presumably one ungrounded conductor to each pole. Or must you use a breaker with lugs on both ends in this situation? I bet the panel in question is suitable for use as service equipment (some only rated 30 amps may not be, most others are) and if you can land a service conductor on there why not a feeder tap?
I understand.
I was simply speculating about a possible solution as have others in this thread. Since the OP is playing forum tennis with back to back questions and answers rather than giving us all the information upfront, I decided to post a solution that would cover ANY scenario.
I understand.
My apologies. What other information would you like?
