nolabama
- new orleans la
We are setting a machine for customer that requires 240vac 4 wire - service is 208/120 - machine is a currency counter - Foreman say's it wont work - Master says its fine - what do you guys think -
My guess is that "240vac 4 wire" means 120/240 1ph + EGC.nolabama said:We are setting a machine for customer that requires 240vac 4 wire - service is 208/120 - machine is a currency counter - Foreman say's it wont work - Master says its fine - what do you guys think -
LarryFine said:Because it's easy to presume that, to most loads, the difference between 240 and 208 is easily within tolerances. Apparently, the knowledge isn't that common.
But with a machine that costs $125,000, has 220/230/240v taps or settings, costs $125,000, requires a neutral, and costs $125,000, you don't even think about making such expensive presumptions.
Oh, did I mention that this machine costs $125,000?![]()
This is doable with a buck-boost transformer.nolabama said:toshiba asked for a 240vac with no netural
recieved callback today from GC he wanted us there when unit went in - machine worked fine no problems toshiba rep pluged it in an all is well :smile:
