Hi, I do mainly residential wiring and need some help. A customer bought a commercial building that has 3 phase. I have to run a circuit for a 240 volt kitchen range. The panel is a three phase delta with a midpoint neutral tap. Between A phase and N is 120v and the same for phase C to N IS 120v. Phase B (wild leg) is 208v to N. Phase to phase on any two of the three is 240v. Using a two pole breaker one leg is 208v and the other leg is 120v but together their 240v. Is there a problem using this for the stove circuit? If there is a problem using the 208v & 120v to get 240v for the stove how could it be done from this panel.
Thanks
Thanks
