I have a 957hp, 2400volt refrigeration compressor, and have a couple of questions regarding sizing of the feed for the motor/starter.
1. Since this motor is an odd size, what is the correct way to determine the FLA by NEC code?
2. What is the correct method (in keeping with the NEC) to determine Medium Voltage cable size for a given ampacity? For instance, table 310.16 is for 0-2000volts, so where is a table for >2000volt applications?
Thanks!!
Thanks!!
