240v baseboard heater thermostat wiring - funky...
OldeTimer
Midwest
Journeyman
Hey all,
I had 7 thermostats and could get all but two wired. You think I have a chance to find a digital thermostat that can be wired this way? They did these two with some kind of funky wiring. Ill be contacting some manufacturers but just wanted to see if anyone has ever seen this. I was able to rewire all the other to the normal Line/Load scenario.
Not clear on the funky wiring. Are these two relays feed from a combination 240 to 24 volt transformer and built in relay ? Have used these transformer relay combinations control to power a 24 volt programmable wall thermostat to control baseboard heaters. Good thing about the 24 volt thermostats they are more accurate then the typical single or two pole 240 volt line thermostats.
Hey all,
I am assuming you maybe wanting to replace existing mechanical thermostat with a digital thermostat and you ended up having two were only switching a single line? This would be greater possibility of encountering if it is a single pole thermostat.
Might be physically possible to have a two lead digital thermostat but I am not aware of any that actually are like that.
Not aware of any digital line voltage electric heat thermostats. How about some manufacturer and numbers for the ones you are talking about?
-Hal
Please clarify who you are asking and what you are asking about. Surely you have seen digital line voltage electric heat thermostats before.
If replying to this:
I don't know if they exist or not, was just saying it maybe could be possible but have never seen one. Would be sort of like how two wire electronic timers, occupancy sensors, etc. function if they would do it.
Actually, I have not. Around here nobody uses electric for heat. Any that I have seen is the usual dial type.
-Hal
I guess that makes some sense. Electric heat is still higher cost in general than from NG or LP, maybe even fuel oil though it isn't too common here, but is quite a bit lower than where you are like maybe about 50% less for average residential customers from some of the information I have seen. We used to have even lower rates in winter months because peak demand is lower in those months and they wanted to encourage more electric heat installations. But that has kind of gone away in the past 10-15 years and no longer have those winter rates. Back when they had those rates electric heat sometimes did cost less to use than gas did.
