gs3jcb
- Sharpsburg, Ga
ok humor,:thumbsup: thanks againNo criticism just humor....![]()
Yes, we know. If you were to measure phase to phase voltages you would see them all to be 208V or thereabouts. There is no 240V accessible in your service. Your options are:
1) get a 208V to 240V transformer
2) replace your 240V heating element(s) with 208V
3) be satisfied with the lower heating ability of the 240V element(s) operating at 208V
If 208V will not suffice, you can install a buck-boost transformer in boost mode and get a full 240V.
If his kiln is supposed to operate on a 240V split phase service, why would he need two transformers? Wouldn't a 208V primary, 240V secondary with a center tap do the job? He might not even need the center tap.electic supply place is saying I will need two 208v to 240v transformers with 50 amp secondary that sound right? I am out of my comfort zone here
Does your kiln call for 240V single phase or three phase? Former, one required; latter, two required.electic supply place is saying I will need two 208v to 240v transformers with 50 amp secondary that sound right? I am out of my comfort zone here
It looks like a 10 kVa transformer will cost about a grand.
Seems to be more guys out there that never ran into a high leg system before and learn about them the hard way when connecting 120 volt loads to the high leg.you are right I have not been around a wye system that was why it through me with no high leg, and you are correct, but with that be said I am not go to get 240volt for this kiln
Looks like you can get one on eBay for around $300 or maybe less.
I would first connect it to the 208 voltage, and see how it works before I spent any more money. It might work fine for you needs.
I get a error read and the book that came with it says it has to be 240v not 208or 215v so it want even fire with the voltage that's there tried that was why I was called to figure it out, the customer doesn't want to change the elements to a 208 system.
