bassphisher
Will all 240v GFCI breakers work without a neutral.
I inspected a hot tub the other day that only required 2 phases and a ground to operate.I looked at the installation manual and in it was a wiring diagram that showed the neutral from the panel brought out to the breaker (no bonding)on the outside of the house and then from the breaker to the hot tub 2 phases and the ground.
Can I assume that all 240v GFCI breakers will operate like this or does it have to be a special breaker.The manual does not address this.
