I recently had and issue with a 240v three phase Delta system while on the job. While testing a condensing units 3 pole breaker for voltage I found 235v A phase to B phase and 0v C phase. So then tested phase to ground and found 235v phase to ground on both A and B phases. Never ran into that before. I ended up tracing out the C phase to a blown 400A fuse. Installed a new fuse and to my surprise I tested 235v phase to phase across all three phases but still 235v phase to ground on two phases. I ended up finding the fault in a wire way down into the system. The fault went through three sets of fuses before the 400A blew. I cleared the fault and phase to ground voltage went back to normal 120v across the 2 remaining phases. Any ideas on the 240v phase to ground?
Thanks.
Thanks.
