FountainGuy
- Metro Atlanta, GA
I have an EE that is specifying (3) #3/0 + #6G for a 200A power feed to a non-residential site.  Shouldn't it be just (3) #3/0 (two hot and a ground), just like for power to a house?
The only unique thing about this power feed is that the power is going from the meter and disconnect to an ATS first (ASCO model ATS-G-1PH-11BE-3R), then to the load center. I know that you can order the ATS with an optional full rated neutral configuration, but is the neutral lug on the ATS not necessary for this feed as the main panel accepts just two hot and a ground?
