Transportation Guy
- Williamsburg,VA
Hello all. I have a customer here at a large resort who has in my eyes a few hazardous outlets istalled outside. There are 240VAC luminaire poles fed by a Dp 30 AMP overcurrent protective device. The grounds maintenance supervisor was asked to run "Christmas" lights to all the trees that surround these lights. The sup. did this by installing an extension cord at the bottom of the pole, tied into one leg (only needed 120VAC) and a ground. There is not a neutral present in the circuit. They installed GFCI outlets with weather proof covers that give this the look of a safe and functional GFCI protected installation but this is not the case. There are also some of these installed close to the outdoor pool. Couldnt this allow objectionable current to "seep" into the ground as well as metal parts?
Thanks,
Pete
Master Electrician
VA
Thanks,
Pete
Master Electrician
VA
