240volt Delta non grounded
Finally got back to take readings on this transformer, I don't always get to set my own priorities...
Voltage phase to phase:
X1-X2 240v
X1-X3 240v
X2-X3 240v
Voltage phase to ground,
Main Output breaker on;
X1 135v
X2 145v
X3 135v
Main Output breaker open/Leads to breaker disconnected attransformer
X1 146v
X2 132v
X3 132v
Ohms to Ground measured with 1000v Megger
X1 13G
X2 13.5G
X3 14G
X1-X2 240v
X1-X3 240v
X2-X3 240v
X1 135v
X2 145v
X3 135v
X1 146v
X2 132v
X3 132v
X1 13G
X2 13.5G
X3 14G
In your OP you said you had a ground detector lit up. What is being used for a ground detector? Is it still lit up? The numbers you gave look like an ungrounded system without a fault.
Looks like Delta with no corner grounding. You still don't know if there is a center tapped neutral. Can you see the service wiring? You can look at the POCO meter and the FM number will tell you what the service is. A 4W Delta with power leg will have a FM 15S meter. If it's a solid state meter, it may say 15S/16S. 16S is for 4W Wye. If it's a CT service, it'll be FM 8S/9S. Older services may use different meters, but not worth discussing. Based on the Ohms to ground, I'd say it's an ungrounded 3W Delta. That's why there's a ground detector. I've never seen a 4W Delta with an ungrounded neutral. If there's a step-down transformer between the service and you, I can't be of much help.
Edit timed out....
Duh! I read your OP and I see it's a 480/240 transformer fed panel, so leave me out of the picture...I'm just a lowly POCO guy.
X1-X2 240v
X1-X3 240v
X2-X3 240v
X1 135v
X2 145v
X3 135v
X1 146v
X2 132v
X3 132v
X1 13G
X2 13.5G
X3 14G
While not a transformer test expert, 13G-Ohm to ground says to me the transformer is fine.
Regarding voltage to ground, if PoCo primary loads can be unbalanced, can secondary voltages be proportionally unbalanced downstream?
