hvac809
- Rhode Island
I'm trying to understand what I believe to be a basic/fundamental theory, however, I seem to be over analyzing. On many hvac units the 24v control transformer common is grounded to the unit chassis. This brings the common to ground potential and helps with troubleshooting. Wouldn't grounding the common, which it obviously doesn't, unless in the event of a short, cause unwanted voltage to continuously energize the chassis? Why is it that it is safe to do this and the common has no voltage? Is the voltage lost/consumed through resistive loads in the circuit, such as contactor coils? I assume there is a logic and basic explanation to this and I just need it dumbed down. Any info is greatly appreciated, thank you!
