I dont often see feeder taps on residential and am considering using one.
The property has 2 single family dwellings. One existing and one now being built. On the new dwelling there is an attached shop / garage.
For logistical reasons the existing dwellings service is changing to a feeder and being moved to be fed underground from the ADU.
On the ADU there will be a 3 pack meter center with 2 200A mains. The 3rd meter / feeder is a 100A to the shop / garage space so it could be a common area if both units were separate rentals. Since the owner is living in the existing dwelling he would like the shop on his house meter to avoid the 2nd meter fee.
There is about a 20 foot run of PVC from the meterpack to the 100A main breaker panel in the shop mostly under concrete slab. I am considering making a tap off the 200A existing house feeder in the meter pack for the 100A panel.
The tap conductors would be #3 CU and not more than 25 feet long to the 100A main.
When the home owner moves it would be a service call to undo the tap and land the wires on the 100A main in the meter center.
There is plenty of room in the meter center for a tap, but since this is not installed yet I could do something different.
Is this code? I think the reference is 240.21(B)(2). Is there anything somewhere else that blocks this on residential?
Thanks in advance
Thanks in advance
