Carultch
- Massachusetts
Consider this example.
You have a 100A circuit, which would ordinarily require #3 Cu wire with a #8 Cu EGC. You then upsize it to a #3/0 Cu circuit for voltage drop, which would require a #3 Cu egc. (KCMIL 3/0)/(KCMIL 3) * (KCMIL 8) = 51.6 kcmil = #3.
If you plan on using MC cable, the combination of #3/0 with #3 doesn't exist. Because the #3/0 Cu cable was built with a 200A circuit in mind, which would usually require #6 Cu EGC. This manufacturer planned a #4 Cu EGC to allow room for error.
https://www.encorewire.com/wp-content/uploads/EncoreWire-MC_SL-THHN.pdf
What course of action would you recommend, to work through this situation?
1. Have the AHJ make an exception to approve the #4 EGC and call it day, noting that the metal cladding and cable tray also carry the ground.
2. Change the breaker to 150A, so that 3/0 & #4 is now compliant. Note that equipment manufacturers may limit the maximum ocpd, and thus not allow this.
3. Run a #3 EGC externally, grouped with the cable, in the same cable tray if applicable, and bonded at every opportunity. Note that this will leave an "insufficinetly sized" EGC inside the cable.
