Confused........ I have just finished watching one of Mikes Videos on where to terminate the GEC at the service. Video was very informing and straight forward until about two thirds through. He makes mention that if PVC conduit is used to connect the meter enclosure to the panel enclosure that a separate equipment grounding conductor is not allowed under any circumstances due to t he fact of paralleling of the neutrals. I am confused, lets say you use rigid conduit between the two enclosures and use bonding bushings if required, since the neutral is bonded to both the enclosures along with the ground, wouldn't the RMC be a parallel path for the neutral?
