ggunn
- Austin, TX, USA
- Consulting Electrical Engineer - Photovoltaic Systems
Here's a situation I have seen many times: Immediately behind the meter there is a gutter and several fused discos are connected to Polaris blocks inside it. Neutral is bonded to the GEC in the gutter and not in any of the discos. A PV system is installed on the supply side via open ports in the Polaris blocks. Would you bond neutral to ground in the PV AC disco?
