In 250.24A1 it states that at the meter enclosure is an acceptable point to ground your system. So If I ground at the meter base which is on a pole outside then bring my service conductors into a home 25ft away and not connect to the EGS at the service disconnect then that is code compliant. So then could I ground at the meter then take multiply sets of service conductors to different buildings and not connect to the EGS at each service disconnect?
