gator07 said:Would a 4x4 post with a small 100 amp panal on it be considered a seperate structure, and require two ground rods . I believe so but its not enforced in my neck of the woods! just want to know for my own good.
you would be correct, if that is really the intent, I don't know.Structure. That which is built or constructed.you
Jim,jim dungar said:In my opinion it is up to the building department/inspector to determine if it is a structure.
Scope. This article contains only those definitions essential to the proper application of this Code. It is not intended to include commonly defined general terms or commonly defined technical terms from related codes and standards. In general, only those terms that are used in two or more articles are defined in Article 100. Other definitions are included in the article in which they are used but may be referenced in Article 100. ... Structure. That which is built or constructed.
necdigest?, August 2007
Compiled by Jeff Sargent and the NFPA Electrical Engineering Team
......but the questionable call here is whether the posts that the pool panel is mounted to are considered to be a structure.
The NEC defines a structure as ?that which is built or constructed.? Based on this definition, a frame constructed for the purposes of supporting and mounting outdoor electrical equipment is a structure and, as such, is subject to the applicable requirements in the NEC covering feeders and branch circuits installed at that structure. A feeder disconnecting means is required at this structure.......
M. D. said:I do believe in the State of Wisconsin they have deleted the definition of structure,... However the building code definition is said to be the same as the 2008 NEC definition for the same term,. About 3/4 of the way down the page.. it would not allow cut and paste.
http://www.commerce.state.wi.us/sb/SB-CodeCouncilsElecSumm.html
jim dungar said:According to the local inspector (on a site this morning) a 4X4 post is not considered a structure in Wisconsin.
Dennis Alwon said:So are they saying that only 3 wires are required in this scenario????
If a disconnect is present, it's still where the 4-wire cabling should begin.Dennis Alwon said:So are they saying that only 3 wires are required in this scenario????
LarryFine said:If a disconnect is present, it's still where the 4-wire cabling should begin.
gator07 said:So for example a 4 wire feeder, feeding a sub panal on a post that feeds a mobile home would require 2 ground rods? sorry a little confused!
