250.64 GEC Raceway
Tom, I see what you are saying. I suppose the flex could be looked at as a transformer winding, sort of like a shorted CT around the GEC.
Does anyone know of any links to studies of this "choking" phenomena? I just don't believe that 3 feet of flex is going to have any appreciable affect on the amount of current flowing in the GEC. Does a CT have any appreciable affect on the current in a phase conductor? Even with 1000 amps or more flowing?
crossman said:
I don't know that BX is cable armor. I don't know of anything which is directly referred to as "cable armor". The question becomes "what did the NEC CMP mean when they used the term "cable armor".
Also, when would we ever use bx (AC cable) as a GEC? Single conductor armored ground? I never thought of that as being AC cable. Is it?
I know older services use to use cable armor, basically #8? solid cu wrapped with a metal flexible jacket. Not sure if they make the stuff anymore.
crossman said:
Can you give me a code section on that please?
250.64 (E)
I think they mean this stuff ,.the cable is the copper and the steel stuff around it ,which could be referred to as cable armor I suppose
http://www.southwire.com/ProductCatalog/proddetail.jsp?htmlpreview=true&token=261&desc=Duraclad%20Type%20BAG%20Bare%20Armored%20Ground%20Cable
We used that stuff for residential services. We called it "armored ground". When the CMP says "cable armor" it implies armor that you can install a cable into. But maybe they are talking about the stuff in the pic.
engy said:
The stuff in post#25 is copper conductor in FMC.
No, it is not . It is ;
[FONT=Arial, Helvetica]
[FONT=Arial, Helvetica]Southwire Duraclad? Bare Armored Ground Cable is suitable for use as a grounding electrode conductor for Residential Service Systems.[/FONT]
[/FONT]
