...or the starter contacts are shot, or...If it has start capacitors it's not three phase. It may have a three phase starter wired up to single phase.
How old is it? When did this start happening?
It could be a bad bearing in the motor, it could be a problem with the unloader for the compressor, it could be a loose connection in the circuit, or it could be a worn out starting switch in the motor.
Abnormally frequent starts will also blow the capacitors. They either need to add tank capacity, or change to an air screw compressor.
