let the light shine
- Texas
Recently, The roofing contractor closed the rooftop with a rubber layer. the conduit for the WP outlet wasn't installed in time so I have to come out on the wall outside to install and penetrate through the bldg to a J-box which provides 277v back to the panel. I can set a j-box ahead of the277v panel and pipe over to the 120v panel. is this ok per grounding by code or should I rely on the 277v grounding conductor?(Ibelieve that I need 2 grounds. 1 120v and 1 277v.)
