A change in 2014 NEC 210.52, not certain which subsection, calls for 120 volt receptacles at ALL services. This will mean services that supply a single load such as a remote well will now need a 120 volt receptacle installed at the location as well
It will effect irrigation services in this area as they are almost all 480 volt, and the only 120 volt available is usually limited to control circuits with limited capacity.
IMO NEC dropped the ball some on this, at least for this particular application. 120 volts is hardly ever needed for anything, and when it comes to servicing - they people that do much in this particular type of servicing have portable generators on their service trucks, and the power may be needed at the service point or it may be needed 1000 feet away down the center pivot system. Even when doing initial installation, when 120 volt power may be needed the most - by the time you have things ready for operation of the 120 volt receptacle it is generally not needed anymore:slaphead:
Besides, why didn't they put that rule in long time ago, today's cordless tools mean less use of such a receptacle in general anyway.
