electricalperson
- massachusetts
I don't think there are too many mines on Cape Cod.
i was just wondering so i can look to see what they require. ill probably never work in a mine im just curious
if i needed a bulb above a fire extinguisher or above the master box outside or whatever id just use 120. what happens when the janitor replaces the burned out lamp with a 120 volt one?
But it does burn quite brightly for a few seconds...It burns out.
it may not be that you need a 277 volt lamp over a fire extinguisher....
perhaps you need a fire extinguisher under every 277 volt lamp?
The Electricians file a grievencewe would mess around with 277 and 480 in high school. we had 277 volt lamps up high that we would control with different switches and all that good stuff. i never used a 277 volt incandecant in the real world though. if i needed a bulb above a fire extinguisher or above the master box outside or whatever id just use 120. what happens when the janitor replaces the burned out lamp with a 120 volt one?
You can do that with a simple diode in series with the load. It also reduces the brightness quite a bit.Any of you guys ever tried these:
http://www.acehardwaresuperstore.com/the-button-light-bulb-saver-p-22432.html?ref=42
